H16 / 9005 question
I know 9005 are different.
It was a separate question.
When your LED 9005 bulb is inserted into the housing, do the diodes sit parallel to the ground?
You also say the PHillips H16 are your favorite but you did not answer my question in regards to lumens.
The one kit is rated at 2500 lumens while the Philips is 700. That is a drastic difference. Why are the Phillips better at such a low lumen?
I apologize; i misunderstood your question.
(1) The diodes will be in the 3 and 9 o'clock position.
(2) XenonDepot kits are brighter a they can technically be used for headlight applications. The Philips H16 LED bulbs are not designed for headlight application a they are not bright enough. Brighter is not necessarily better for fog lights, as you may end up disrupting on coming traffic.
Steve
Jhunt
