Having trouble getting strut assembly out
tacozappy
I,ve finally knocked my strut loose, but its still quite stuck in their and i'm not sure how to get it out.
Heres a link to the pics.
Any suggestions would be great!
<a href="http://tinypic.com?ref=1zoxfr8" target="_blank"><img src="http://i40.tinypic.com/1zoxfr8.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com?ref=dnltvr" target="_blank"><img src="http://i39.tinypic.com/dnltvr.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
<a href="http://tinypic.com?ref=6f6rk3" target="_blank"><img src="http://i44.tinypic.com/6f6rk3.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Undo the two large bolts just to the right of where your jack is located that hold the a-arm to the hub assembly and then remove your jack. The whole a-arm will drop lower, letting the strut out.
And after doing the above, you might have to put down pressure on the lower bolt in assemble to remove.
CAUTION NOT TO DAMAGE THE LOWER BALL JOINT BOOT IN THIS PROCEDURE.
Run a search on this removal procedure, it will explain and help you understand.
Did you take off the third nut on the top mounts? (Not to be an ass, just making sure)
Take off the sway bar too like ark suggested. It's only 4 bolts and the links.
