Headlight Beam Question
MikeinCincy
I was following my girlfriend the other day driving and she called me and informed me that one of my headlights is "brighter than the other". I figured, how could this be? My truck is only 2 years old. Are the headlights already dying? This can't be.
So, when I got home, I parked my truck with the headlights on and got out and looked at them head on. I started crowching down and notcied that the driver side got very bright before the passenger side. This was on level land, btw. So, I am figuring that the driver side headlight is pointing higher than the passenger, but not by much (but enough for her to notice I guess!).
So, the question remains, is this normal? Should my driver side headlight beam be pointing slightly higher than the passenger side? I have never altered the position of the headlights, but I also bought my truck used at 20,000 miles. Any and all help is greatly appreciated, as always.
-Mike
My '07's right headlight is aimed a hair higher than the left. I just chalked it up to mis-calibrated robot:bash:
Drive up to a wall at night. You can really see it when you're about 15-20ft away.
:cheers:
:cheers:
Wait, so your right headlight is higher than your left. By right, you mean your passenger headlight?
Mine is too. I think it's a safety thing. Just in case someone on the opposite side turns on his/hers high beams at you, you can focus on your right side to make sure you're not falling off the road.
Actually, I think it's the driver side headlight is aimed lower. It's lower to reduce glare for on-coming traffic.
Yup...that's right!!
MikeinCincy
Indeed the right side is aim slightly higher...but you cannot tell if you're looking at the headlights, only when you are against a wall.
Not obvious like what your gf sees.
How to aim the headlights on an '07?
http://www.toyota-4runner.org/showthread.php?s=&threadid=41882
You'll see my post...that should help you out.
Thanks a lot guys. All makes sense. I am just glad I don't have to fool around trying to adjust it. I guess that's just the way it's supposed to be! You guys are great.
MikeinCincy...
I think you do need to adjust the headlights, because it's not suppose to be noticably off when squatting down.
icantsee said:
MikeinCincy...
Oh. Darn. I will run a few tests tonight. Is there an ironclad way of knowing for sure if they aren't positione dcorrectly? I don't want to start fooling with them if they don't need it.
Fooling around them with them is really simple, don't worry if you need to.
I have adjusted mine a few times to deal with my various lifts.
Headlight aiming
icantsee said:
MikeinCincy...
The right side low beam headlight is supposed to be higher by 2 inches at 25 feet. This is the aiming requirement for the 4Runner and a Mercury that I have the shop manuals for.
tuṣṭāva
