Help! Changed Headgasket Now Bad Fuel Injector?
fable
2004 4runner 4wd 121K
Paid my mechanic $3,000 about two years ago for a headgasket job. I have only put 7,000 miles on the engine since then. Now I am noticing a small infrequent tremor at idle, and there is a little stutter when the engine first starts up.
Mechanic says that there is a failure on cylinder 3 and after swapping a coil, he determined that #3 needs a new fuel injector, cost for the job is $500. He said the other option is I could also replace all fuel injectors, all together that would be $1400, but he is suggesting that I do the first option.
I've read a lot of the headgasket failure threads, and part of me is concerned the headgasket job was never completed properly. My mechanic has good reviews, so I want to trust him, but I'm not a rich man.
I've gotta give my decision tomorrow, can you guys give me some advice as to what you would do? Thanks in advance!
WitchHunter Performance - Injector Cleaning & Flow Testing Services
These guys rebuild fuel injectors, and do FANTASTIC work. They give before and after cleaning performance spreadsheets as well. I think it's $22 per injector. Read the site, and see what they do.
I can't think of a reason that the head gasket would effect fuel system unless he interfered with the fuel system in the process.
Note: if he DID install the head gasket poorly, it could cause a misfire due to loss of compression (not injectors).
I would get a second opinion from a Toyota service center or another mechanic to compare. Seeking a broad spectrum of counsel is probably a good idea. Compare recommendations and go with the one you think is best.
utkrstam
