Help! electrical issue when connecting LED conversion lights
4thGen4.7
Okay so I think I may have blown a fuse or two. So I got an LED conversion kit that includes map, domes, courtesy, reverse, and tag lights. I started with passenger map (for comparison) and then did the doors, dome, back dome and decided to call it a night when I noticed I forgot the driver side map. I made sure it was turned off but left the right one on for light and put the LEDs in. I clicked the button (without the cover) and BLACKOUT. No lights, dome, courtesy, or anything worked.
The 4r starts up, all electrical works except those lights and for some reason the key fob doesn't work.
Im assuming I blew a fuse honestly, but I really just said f*** it and came in the house to ask because I didn't feel like searching through all of my fuses.
So if anyone knows if this is what happened or where that fuse is located in the panel, please speak up, that would be gnarly.
Thanks y'all and Merry Christmas
Since no one has responded I'll throw in my 2 cents worth.
When you're in a better mood track down the blown fuse yourself, you'll learn more by doing than have the answer given to you.
Good luck.
I do not have a test light so my only way of searching for a blown fuse would be to disconnect my battery and pulling each fuse out individually so my best method was to post in here to see if it was and if so where it was.
And though I took the time to read your 2 cents I gained absolutely nothing so thanks for your condescending answer and have a merry christmas, yankee.
the fuse is located in the engine compartment. I did the same thing while replacing the map light bulb and blew one of the fuses. I honestly dont remember which one but I can find out tomorrow when the sun is up again if you need me to. I want to say it was a 10A fuse labelled dome or accessories or something similar.
