Help! heat stopped and so did the engine
Jason_M
I'm new here. I have a '99 sr5. V6 with about 190k on the clock. I was driving for about 5 minutes the temp gauge went up to normal but the heat never got warm. Then it just stopped running and coasted to a stop. It turns over but won't start. Any ideas? Thanks in advance!
You are going to need to do a lot of troubleshooting.
lets start with is the radiator full?
Do you have spark?
Fuel?
Timing belt still intact?
I could hypothesize that:
water pump locked up (no heat) and then it took out the timing belt (no run condition)
but its hard to tell with out looking at anything or having a lot more info.
Stick is dead on. My guess, water pump seized up, broke, took timing belt out. Not the end of the world, $650 ish and shell be good again. But trouble shoot it first, maybe you'll get lucky.
Thanks for the information. I checked the radiator and it was full. This all happened last night and it was sitting alongside the freeway. I just had it towed to the shop. I suppose I will find out today what the issue is. If the timng belt do go, is that catastrophic to the engine?
No. It's a non-interference engine. If the timing belt broke all you have to do replace it. Not too big of a deal. Nothing else would break.
You're spot on with the water pump and timing belt. Apparently the timing belt grenaded itself and wiped out the tensioners, pulleys and other belts. Top it off with a new battery and it's about $1360 for parts and labor. Thanks for the quick responses.
That's a lot my man. Most dealers will do this for about $800 ish, a good Toyota Indy Shop about $650. I'd price it out a bit more before you give the green light on that. Timing belt, water pump, tension, belts, cam and crank seals are about $300 in parts for OEM stuff. About a 5 ish hour job.
Or do it yourself at the 300-400 mark. Its time consuming, but very strait forward.
