HELP! I think my power steering about to die
Jon
Lately I've noticed that my power steering is burping and screeching when I try to turn the wheel without forward or reverse movement. Same exact sound you get when you lock the wheel to one side. It drives fine at normal speed. The fluid level is good but it smells like it may be burnt up. No leaks. Would this be a rack or pump issue? Where does the screeching noise come from?
I'll look in a bit but I don't think that's it but hope your right. I always look over the easy things, so used to bad luck.
Change the fluid completely, re-fill with a good ATF. That will extend the pump life if it's just starting to go bad. They do go bad....mine's on it's way out as well. Bad thing is a Toyota replacement is $300. And parts store pumps suck. :(
3rd Gen PS System Flush Writeup (long post) - YotaTech Forums
I'd recommend this ^ way as well. I did mine with the truck running, and the fluid does come out REALLY fast. Plus, the fan blows it everywhere. Ick.
Well it's not the belt. I'll try the flush but what is starting to fail? the pump?
albertpeter156
