Help me diagnose this sound...
masphx
Hi,
I bought a 1998 5speed a couple months back with 168,000 on her. Since then I have put 2,000 miles on the truck and everything seems fine. About 1,000 miles ago the truck started to make a strange sound. Can you help me diagnose it?
Here are the details...
-Normally makes sound after start up (first few miles of driving)
-Normally sound comes in at 2500 rpm (sometimes around 2000) and will only last a second unless I hover around 2500 rpm.
-Engine will not make sound while I just rev it.
-Comes from outside of vehicle (can hear it just as good from driver or passenger seat.)
-No power loss while sound happens. Truck accelerates the same.
-As far as I know sound appears throughout all five gears.
-After initial warm-up and first few miles drive sound ceases to exist except for a few times.
-No vibrations or shaking. Stick does not shake any differently when sound appears.
Here is the video. You can hear the sound at :20 while truck is passing 2500 rpm in first. Sound again appears at :28-:30 in second gear. I hovered at 2500 rpm for a few seconds. Again in third gear at :39 but you can barely hear it. Rest of video is me revving the engine at a stop with no sound and then accelerating though a few gears with no sound.
Sorry about the sound quality. Have tried a couple of times to get this sound on video but seems elusive. It is pretty noticeable first hand.
1998 4runner sound - YouTube
Hopefully someone can help me out and let me know what i should check. I just want to know what is going on with the truck and if something should be looked at before it fails. I might have the truck looked over by a Mechanic. Any good Toyota mechanics in the Phoenix area?
Thanks in advance for the look and the input,
Mason
That metallic rattle sound? The kind that makes me get under the truck and do a little thunking with a rubber mallet on places like the cat heat shield, bumper, brake dust shield, license plates, anything that can make that noise or look for little rocks (those make more of a tinky sound) in a variety of places?
Yes, that is the sound. I'm planning on doing that but this sound make me think its an engine or transmission issue since it make a sound on cue at 2500 rpm.
Could be just the right vibration and position at that rpm and load to make the sound.....
or it could be something else. :D
A friends Passport had the same issue. The mount for the Exhaust Vibration Dampener Thingy (Scientific Name) was cracked and at 2500rpm it would start vibrating like crazy. I knocked it off with a hammer and Viola! Then he sold it.
brendaglores
