me_rikey
Hi all,
I and mainly my buddy will appreciate your help on this. I haven't seen the car yet, but he wanted me to inquire with the great minds on this website as to an issue he's having with his 3rd Gen.
If you have any questions I will send them his way and get a response.
I have a 3rd gen SR5 supercharged
I am having an issue where I experience a rough running, lurching sort of feeling from the engine right at about 2k rpm on the highway at 70mph.
Occasionally in extremely hot temps or when she sits in direct sunlight in the summer you can feel the rough shaking and lurching/hesitations at idle and if you don’t give it gas upon ignition it will die.
This started happening close to the time I did the tundra brake upgrade – a much needed mod due to the nasty vibrations from the warped stock rotors.
Could these be related? Has anyone else experienced this hesitation on the highway?
The VSC TRAC and CHECK ENGINE lights are on. Was throwing a code for EVAP leak and Knock Sensor bay two.
I had the knock sensor replaced with OEM Toyota parts and the code is still there. I installed new bolts on the exhaust manifold and the Evap code went away.
Any ideas?
Any ideas?
