How long has your manual clutch lasted?
Mine feels a bit funny but I think that is the master or slave cylinder going. I got some new ones and I'll replace them some time. Looks like an easy job, and I'll keep the old ones as trail spares. Once I blew my master cylinder on a Jeep Cherokee and I had to drive it across downtown Vancouver without a clutch... that was a piece of junk, but really good off road. Too bad.
OK so back to the clutch issue...
I bought my 4runner 25,000 km ago and the clutch has never been very peppy. It feels a bit sloppy and it engages near the top of the pedal stroke. I am wondering if I should just bite the bullet and replace it pre-emptively now. I was planning on it. I bought the Marlin Crawler one. I don't clearly recall it slipping but with it engaging so close to the top, it must be getting near the end. If this was my daily driver then I could just drive it till it was obviously slipping but I use this truck for long trips into the middle of nowhere so I can't have it causing problems mid way into the trip. It has 291,000 km which is 180,000 miles. Based on comments above it is probably still the original clutch and others have had theirs last longer than this. I replaced master and slave cylinders recently and saw no real difference in its performance but they definitely needed to be changed.
Also while in there I'll do the rear main seal.
Replaced my clutch at 330,000km only because the throwout bearing was starting to make noise. There was still alot of material left and would've probably made it to 400-450k. Normal driving, no towing.
My 2002 Tacoma TRD clutch is original at 177,427 miles. Not as much heavy off roading like when it and I were younger, but has long outlasted any clutch on any vehicle I’ve ever owned.
BillM777
