Inexpensive LED light bars
DZNUTS
Okay, so who is using which inexpensive light bars and what are the results? Please post accompanying pictures as well.
The expensive lights will typically be higher quality. They are also way more expensive. Is it worth it? Only your pocket book can answer that. I run cheap Kawell lights. Easily replaced if broken or stolen. I also run smaller lights on my Dodge truck and Jeep. Jeeps call them rock lights. Toyota people usually say ditch lights. I have about ten lights on my Dodge. 14 +/- lights on my Jeep. Amp draw is about 1amp each. Everything is fused and relayed.
I buy Kawell. However, I suspect the same Chinese maker stamps many names on their products. Most of my lights are Flood. A few are Spot. They make many sizes. I added lights for close proximity. Not into high speed at night.
Amazon link
My Truck with led lights. I've added more since taking these pics. Don't have any current pics of my Jeep with lights.
Dodge Truck lights
Thanks for the info and pics.
I understand the recognized name brands are of higher quality. I know all about designing LED lighting, optics, binning processes, etc.
At this present time though, the wallet and the boss have a few other ideas [emoji6]
some if it is name brand BS but some products are significantly better in overall quality.
I went with Rigid for the 10" only because I was unsure of the fitment with other brands on the hood scoop mount.
But for the lower 32" I wanted the "highest quality" light (in the sub $500 class)
after reading extensive reviews and testimonials I settled on the Opt-7 C2 size.
I was somewhat limited by the 32" spacing on the brackets for the lower mount but could have ran a spacer off either side to accommodate.
Overall, the light output, quality (warranty), and price won me over.
The main complaint you hear with light bars in general (aside from output & build quality) is the condensation issue. many use a cheap housing or gasket material and after a drive in the rain your new light is worthless without pulling it apart to dry/reseal. With the C2 series they implemented a moisture evaporation valve which eliminates any chance of condensation buildup. Both throw tons of light and use same/similar build materials.
considering the Rigid (10") was $300+ and the Opt7 (32")was ~$150 with harness included I have no regrets.
urbanrunner651-albums-bb-picture48105-10-ri-midnight-edition-32-opt7-c2-lp-relocate.jpg
also do not buy into the hype of Aurora brand light bars, their quality have degraded and are only on par with most chinese made/inexpensive light bars.
Buy whatever has the best reviews on amazon.
workingwheelswnc
