inner rack end?
baja1
I have a bunch of loose stuff going on with my '97, after the SS lift I had the front control arm bushings replaced and an alignment done. the shop says I was due for a left lower ball joint and left front inner rack end.......is this the same as a tie-rod end?? plan is to order all the parts and find someone down here to do the installation. I need rear control arm bushings, (the right side has a ton of play) lower balljoints and tie-rod ends. anything else I should be ordering at this juncture? thanks folks!
Just to ensure it’s been said, make sure you order the passenger side tie rods and LBJ (Japanese made OEM or Sankei 555 -NOT Moog) since they’re not far behind. Good luck with the maintenance items!
tuṣṭāva
