johnbyebye's 2000 Limited thread.
johnbyebye
Hey everyone,
I decided to start a build/progress thread. I'm not going to be building much however, and will be keeping my 'runner close to stock. Build threads seem like a fun way to track the progress. I plan to do some mild off-roading once I get the suspension up to snuff, but other than that she's my DD. :)
Some history:
When I bought the 'runner it had 201k miles on it. It has spent its entire life on the West Coast and as a result has very little to no rust. It's a 2000 Limited Auto 4x4 with the E-locker. The ODO is currently sitting at 212k.
The PO had the timing belt replaced at 197k so I knew I was pretty much sold on it since I wouldn't have to do that job anytime soon. I was also sold on the KO2's. I liked the color scheme and the 2000 Limited with E-locker was exactly what I was looking for.
I wasn't too happy with the bumper damage but ultimately decided to fix that down the road.
Shortly after I bought the 4runner, I noticed a whining sound in my transmission. I can't remember if the noise was there when I test drove it since I had so many other things I was focused on. The radiator and rear wheels for signs of a leaking axle seal were the top priority. The drain plug had been stripped causing all the fluid to eventually drain out. Upon looking at the service records I had from the PO, I suspect a drive-in oil shop was at fault for this. I have no way of knowing for sure though.
I added fluid and drove the 4runner as it was until the end of January '17 when I had found a transmission from a wrecked 4runner with roughly 130k. I had that swapped in at a local tranny shop and it's been golden since.
The PO claimed he had no clue the tranny was making noise. I requested 400 bucks back and he agreed to give that to me. Ideally I would have liked enough to cover the replacement transmission, but you catch more flies with sugar and I handled the situation rationally. This was my fault for not being diligent enough, but I am grateful for how things turned out in the end. Plus, I learned more about my 4runner in the process. :)
Here is what it looked like the day I brought it home, November 8, 2016:
Some slight rear sag in the springs. Installing my lift soon.
And here is how it currently sits:
The rear bumper sags on the driver's side. I tried to fix this but the body was actually bent where the brackets mount as a result of the accident. It looks much better than it did before, so I'm happy with it. :)
Currrent builds:
E-locker wire mod
LED Tail lights
Flowmaster Series 50 muffler
Kenwood double din stereo (PO installed)
99 talls + Bilstein 5100 all around
Planned:
New tires
CV's
Fuel Pump
Brake shoes
Hi-lift/mount for my Yakima rack
More to come...
Looking good...99 with e-locker is my favorite combo...
Nice future mod list too...That TBU is on my needs done soon list, since towing my wife's 99limited with my 99sr5. Although my brakes are perfect, they are no match for the extra weight. Problem now is I have to save up for two sets of everything. One for me and one for her...
Thanks man. :) I just removed the plasti dip. Wasn't feeling it. If you're towing then for sure I'd do the TBU. I don't do any towing but figure it'll be a nice upgrade.
I replaced my brake drums today. The originals were still on there and were warped. A significant lip had also developed so getting them off required backing the star adjuster off quite a bit. The shoes still had about 40-50% of the material on them so I'll replace those later. As it turns out, the new drums were warped. According to the guys at OReilly's this can happen if the drums were stored standing upright for long periods of time. Interesting bit I learned. I wasn't particularly fond of having to resurface brand new drums, but it is what it is. Braking is smooth now.
I received two of the four wheels I ordered. I'm stoked to get them installed.
Until next time...
Wasn't sure if I'd like them but I'm really happy with how they turned out. Not sure about the red TRD on the caps though. I might black those out as well. Opinions?
Very nice, I'm liking the subtle upgrades. Flashy does not work on any of the 4R generations (especially 5th gen limited) but that's just my opinion.
Oh man, life sure does get in the way sometimes.
A few changes since I last posted:
I got my 1" lift installed with the '99 tall/Billy 5100 combo. There is some sag in the rear with my tools and emergency supplies so I installed a set of airbags. They helped a lot, but I forgot to compensate for my 1" lift and cut too much off the coil bumper. Right now they're at 18 PSI but it's still not high enough to overcome the sag. It's pretty close though. I have to add a spacer of some sort below the airbag to get things exactly where I want it. Any tips for this? I was going to cut 2 half-inch pucks off the rubber bumpers they included.
I also snagged a Yakima LoadWarrior and am currently waiting for the spare tire carrier so I throw my spare on top.
My CV's tore a bit after the lift so I picked up a new set from NAPA and will get those installed sometime soon.
Current pic:
Cheers,
Scott
11 months later lolol.
I will be taking a trip to Yellowstone/Grand Teton in July and driving the 4Runner all the way.
Before then I have a list of things I need to get done. Among them are the CV's and fuel pump.
I am going on my second transmission that will be installed on the 14th by a local shop. I hope this is the last of the transmission problems that I encounter. :rolleyes: Otherwise my next transmission will be directly from Toyota.
VERY VERY nice!!
Also love the Chris FIX decal!! I love his channel too!!! Many thumbs up from me all the above.
Looks good. Shocked to see the PO gave you money back. Hope you sent them a Christmas card or something, HA.
Looks good. I like the black wheels.
Very nice truck sir !! I really like the new black rims. They look very sharp!
Thanks man!
VERY VERY nice!!
Well...I used to be a big fan of his, but his channel took a different direction with the drift cars, etc. So I don't watch his videos anymore since I don't relate. I removed the decal lol. :whistle:
Thanks man. You catch more flies with honey as they say. I was respectful so he was willing to give some cash back.
HexAndHorsepower.5thGen
