Keyless entry piezo location
dr_optical
I'm trying to locate the piezo for the keyless entry chirp on my 2005 4runner limited. It sounds like the chirp is coming from underneath the master cylinder in the engine compartment, but have been unable to find it so far. Alternatively is there a way to program the remotes to disable it? I've tried following the steps provided for other models but none have worked so far for my 2005.
Thanks,
Andy
I'll try to research some more (has been listed previously) & edit this, but it is inside the front fender.
found this below in another post:
"Find the source of the noise under the hood, directly down from the d/s hood shock. There is a wire going inside the wheel well. Pry the black plastic ring out, then press the black dot (lack of a better description) next to the hole.
This will pop the noise maker from its mounting and allow the thing to be pulled out and then be removed from the wire harness that it is plugged into.
No more beeps, the lights still flash........... "
__________________
__________________
Thanks. I'll look again in the morning and let you know what I find.
Andy
Trdoffroad916
