King Coilovers - Adjustment Questions
Bumbo
I've been hearing you need to remove the coilover from the truck in order to do any height adjustments on the threaded collar.
Is this true, or can adjustments be made while the coilover is still installed?
they can be adjusted with them still installed. jack up the side, remove tire and i find that a punch that fits into the adjuster collars works better than the spanner. loosen the lock collar and adjust the lower one to desired spot. lock the top one down after.
easy peasy.
In my experience, adjusting the shock was NOT possible while installed. Where the reservoir tubing exits the shock body, it blocks you from being able to turn the collar enough to grab the next catch point. It was a PITA to get it where I needed it with having to remove and reinstall just to adjust it a little but I haven't needed to adjust it since.
Next time remove the reservoir from the bracket then use a line wrench to loosen the hose at the shock just enough to twist the elbow up and out of the way.
Still don't believe you'd be able to loosen and tighten the adjustment ring with it still being in proximity to the shock tower.
You have to make sure the bolt for the ring is on the outside, yes. That's how we did my buddy's king adjustments on his Tacoma. Multiple times.
Sent from my Nexus 6 using Tapatalk
