Knock Knock, Whos there? (Need help for the response)
MK1Power
Sadly, this isn't a joke but....
Here's what happened. Was driving on the highway - oil pressure light started flashing, started to get a really bad knock. Pulled over, checked oil level. Was like a quart low, I added a quart and let it cool down a bit. Started to knock a block away from my house. Parked it and been diagnosing a bit. Only engine code stored was MAF. I cleaned that but it's still knocking.
Symptoms:
-Only knocks once has been warmed up, at cold runs perfect
-Pulled each plug wire while running to try to isolate the noise more, but the noise wouldn't stop.
-No lights are on dash - no other codes stored
-Knock is NOT consistent, especially as RPM fluctuate...
At idle - Engine Cold
https://www.youtube.com/watch?v=RAWNwotxJVs
At idle - Engine Warm
https://www.youtube.com/watch?v=1VL3eLG1Zc8
I'm really stumped on this one, I happened to find videos of other 4runners with the same exact noise, but no cigar on issue...
Thanks.
If it's a bearing, possible to replace just the bearings (with the engine in the truck) provided the journals aren't too damaged?
BillM777
