knocking sound under the hood
jhlscut
first of all, many thanks to people who have helped me. i bought my 04 v8 limited about three months ago. had a couple of problems and all were solved with the help i had here.
now it seems there is another problem. i can here faint knocking sound while sitting in the truck. when i get out and kneel down at the front wheel, the sounds grow much louder. it comes from the bottom of the engine or transmission. any idea?
Check the exhaust heat shields. There is one right where you are talking about and it comes loose often. Mine did.
Take it by your mechanic and have him/her take a look... if its a rod bearing, maybe they cancfix it before you toss it...
Take a video and than we will figure out.
Might be leaking manifold wich is specific tick sound or it might be a fuel pressure valve or whatever they call it.
I replaced my both manifolds already.
I still have a knock noise sounds like valves but only when it's really cold and first start up at the morning. It goes away after 5 minutes driving and it's definitely this fuel pressure damper
the sounds is always there. no matter after a drive or a cold start. it is there when the truck sits. hopefully, i don't need to go to a mechanic.^^
good idea. i will take a video. ^^
