LC Shocks with toytec Superflex Coils
gocrazyrc
Hey guy can I use LC shocks with Toytec Superflex Coils.
or is it better to use the 5100 Billys long travel shocks.
Cheers
or is it better to use to use the 5100 Billys long travel shocks.
Cheers
Yes you can use LC shocks. Tokico OEM shocks for the LC will be longer, you might have to research a little to find correct part#. They will give you a more OEM ride as where the Billys will be a little more soft. I like the OEM ride and it helps stiffen up the softer coils like the superflex and LC coils.
Thank You for your in put. [MENTION=50342]JayRolla[/MENTION]
I'm running Tokico LC shocks with Superflex coils and it's PERFECT for me. A bit stiff unloaded but plush with 150+ pounds of a weight (bumper, cargo, or whatever).
The LC shocks were initially a temporary measure, but I'm super happy with them and not looking to go with a race shock for the time being.
With weight they perform, and the compressed / extended specs are near perfect for a 4Runner!
Make sure to get the proper hardware / washers. I went to without at first, and it wasn't worth it.
This is Great Info [MENTION=108791]SL28[/MENTION] Thank you for your time.
Cheers
mek
