Leaking front Shock, thoughts on replacement
lost_in_the_woo
I have look through the forum and I am still undecided.
I have a leaking front drivers side shock. So I have been thinking about replacing all four with something better for quite sometime.
Here is where I am at:
5100 with new springs
Radflow replacements coil overs.
Fox 2.0
sway-a-way 2.0
I run air bags in the rear for hauling trailers. I would like to bring the front up a little and I don't plan on running anything bigger than 265/70R17 that I am currently running.
The vehicle is first most a daily driver. It sees fewer trailers these days as my primary vehicle is a Ram 3500 4 door long box diesel.
I want good highway performance as well as gravel roads and through the field. I will not be racing the vehicle nor will it see hard core off roading.
Please let me know which option you feel would best suit my needs.
Thank you,
Hard to beat 5100's with FJ coils for a low budget options, but if the funds are available you can't beat the Radflo kit. You can order directly from Radflo and request the "Overland Warehouse" spec kit. This kit was designed specifically for the 4th generation 4runner whereas the normal Radflo kit was designed for the 120 platform in general.
The Radflo kit is really overkill for your needs, but the rear would be helpful for the towing. Also, the on road ride will be better IMO and the shocks are rebuildable so it would help in the long run.
DJNutshell
