leaking suspention
kaatsal
I have a 2007 sport edition all 4 struts are weet with oil
the question is if there is a leak do I need to change the dampers too with all the above
please help. what you recommend
struts are the dampers. Please post pictures.
yes replace both sides. might as well renew and do all them. rear shocks are cheap
Sounds like its time for new struts and shocks... +1 on pictures.
The fronts you would probably need to go to a shop, but the rears are very easy to do yourself. If you can take a tire off, you can change the shock.
If you buy new, I strongly recommend the Bilstein 5100 series if you are going to keep the stock springs. Most people consider a very mild lift at this stage too.
If you want to go cheap as possible, you can always ask around for sometimes factory take-off suspension that goes for cheap.
