LED bar?
Depending on how big you want to go you should be able to find a decent bar. I purchased a 42" curved on Amazon for 160 and then 15 for a harness. Measure the size youd like then look on Amazon or ebay make sure it either comes with the brackets you need or you order them as well. Give me a minute to pull up the brand of mine
Look at Tuff Led Bars... Good price and high quality. Mounting brackets allow for angle adjustment as well
Rafal
For you guys that have them mounted about the windshield or on the front of a roof rack, where are you running the wires?
Down the door seam between the 2 weather strips.
Added some crappy pictures to show. I have the wires running through the driver's fender to a hole into the engine compartment.
Interesting. No issues with the seal ones the door closes?
No. Main issue right now is I don't like to slam my doors on my truck and I have to now because of the thickness of the wires. I reglued the weather stripping so it's snug and I've water tested it and with the compression of the door there are no leaks. Ideally in the future I want to notch the stripping to fit the wires in it and still keep it weather proof but this will do for now.
