LED headlights on 2007 4Runner Sport V8
Hey, those look pretty good. The really like the smooth lighting over the individual bulb. I'll have to look at that company when I get to this point.
I have had these on my 4runner for over a year and no issues at all. Very well worth the price and look tons better than the stock headlights.
Did you have to do any additional wiring to get the LED DRL bar to run with DRL? Mine only illuminates with my headlights on. I assume it's relatively straightforward but wanted to get any pointers from someone that's done it before.
LED Headlight Bulbs?
Are you running LED headlight bulbs as well? I just purchased a set of the SPEC-D on Craigslist. I am wondering if I could run them inside the dustcover, as mine are hard plastic and the LED headlight bulbs have a fan. Thanks
I am currently running just a halogen bulb but I am looking into buying the TRS Morimoto LEDs. I may have to adjust them some so I will look into it. I also see you are in Smyrna. I am near Canton in Cherokee County.
Those are very nice looking! Please update after you’ve run them for awhile though. My experience with aftermarket lights has not been good regarding condensation problems. I’ve done everything short of completely baking mine apart and regluing and still the problems persist. I’m convinced that it is faulty venting on mine that is the culprit since I’ve sealed absolutely every other way moisture could enter.
Do those LED strips turn amber for turn signals?
Same issue here. Decided to go the cheap route and got regular replacements off ebay. 9 months later the left front developed the condensation problem. After a couple calls later, they were sending me a replacement headlight assembly and covered it under their 1yr warranty. The right side hasn't had this issue yet and hopefully it never does because the warranty is about to expire! Anyway, here's some photos of the condensation in the one I had...
H.Sikina
