Lift finally installed...
sonerick
I finally got around to installing my lift over the holiday weekend. I went with OME 885's up front, Toytec Superflex coils for the rear, and Bilstein 5100s all around. My XREAS wasn't leaking or anything, but after installing the lift it was apparent that it just wasn't performing that well after 100k miles.
I used the how-to guides from this forum and from the 120 forum (the one without spring compressor for the fronts), and found the install pretty straightforward. I did run into a couple of hold-ups though:
  1. On the rears, I found it difficult to squeeze the taller rear springs in, but a quick trip to Autozone to rent a spring compressor took care of that problem.
  2. Also on the rears, there is a metal bushing retainer for each of the XREAS shocks that had rusted to the frame so I thought they belonged there. When I installed the 5100s, despite jacking up the rear axle, I just could not get enough thread to screw the top nuts on. But I realized my mistake, popped off the old busing retainer, and problem solved.
  3. On the fronts, I didn't realize that the bushings and retainers were not included with the 5100s, and I destroyed the existing upper bushings getting the XREAS top nuts off. I put the torn bushings back on for now and it feels fine, but I have new upper bushings on order right now and will be installing them as soon as they come in. The lower bushings and retainers looked fine, so I reused those.
  4. Also on the fronts, the XREAS shocks had rusted so badly that I couldn't get the lower bushing retainers off for re-use. I set them aside and planned to use an angle grinder to get them free, but completely forgot about them. So I completed the front install, and just as I was reinstalling the sway bar, I realized I had left them out. Long story short, I had to re-do the entire front install. Do not forget these lower bushing retainers!
  5. And finally, I tore one of the lower ball joints trying to pry down the LCA because I didn't want to loosen the eccentric bolts. Easy fix though, so I wasn't too upset. I probably should have just loosened the bolts in the first place to give myself some more wiggle room for the install. Oh well.
All said and done, I'm extremely happy with how it turned out. I had new tires put on yesterday and an alignment done. I went with 255/75/17 Firestone Destination AT's (white letters out), and am pretty satisfied thus far. They are a bit noisy on the highway, but this is to be expected from an AT tire. Once I order up some Spidertrax, it should look pretty mean.
For the alignment, I told the guy at the shop to try to get 0 camber, 0.04 toe, and max out the caster. Here's what he was able to do:
Before
LF Camber: 0.9
LF Caster: 1.4
LF Toe: 0.16
RF Camber: 0.7
RF Caster: 1.0
RF Toe: 0.10
After
LF Camber: 0.1
LF Caster: 0.6
LF Toe: 0.06
RF Camber: 0.1
RF Caster: 1.8
RF Toe: 0.07
Since the caster is way out of spec, the truck is slightly twitchy, but not much worse than it was before the lift. The steering wheel is still perfectly centered and it drives straight as an arrow. I'm debating whether I want to add some new UCAs to get it completely within spec though.
Oh and I also figured it would be worth mentioning that after the lift, both my inner CV boots started to leak at the small clamp within the first mile or so of driving. After reading some threads on here, I expected that to happen to be honest. I have some hose clamps on there as a temporary solution, but plan to re-grease and re-clamp when I find the time.
Here's a quick iphone pic:
Looks great, though I am a little biased! I really like those tires, my Dad runs them on his Tundra, great handling, good grip, and very quite imo. They are way quieter than my Hankoks.
Wow that looks great. Would you mind telling us what you paid? I am debating full OME with the toytec rears or that set-up. How is the ride?
Looks good, what do you estimate the overall F/R lift as? I personally like at least an inch of rake.
I've been waiting for it to settle a bit (which it has) before taking measurements. Initially the front end was higher than the rear, bro lift style. I'll post some numbers up ASAP. I do have some driver's side lean going on, but I'm not too concerned about it. I also prefer a bit of rake, that's why I opted to go without the Toytec top-plate spacers.
I bought the coils from Toytec for $367 shipped. I purchased the rear Bilsteins for $134 shipped, and the fronts for $175 shipped. Grand total of $676.
The ride is awesome so far. It's firm and truck-like but not harsh like some describe with the full OME setup. Should have come like this stock. I'm very glad I went with the Superflex rear coils as I have no plans for a rear bumper and do little towing. Whit the 5100s, dampening is much improved over XREAS, buttery smooth at both low speed and high speed. Also I have way less brake dive and body roll in the corners. I have yet to take it off road though, but I plan on wheeling the **** out of it this weekend.
I agree it would look pretty badass with 285/70's, but I'm not ready to give up my mudflaps or start trimming just yet lol!
I do need to take off the running boards at some point though, it'll look even taller after I do that.
I didn't trim or take off my mudflaps and we have basically the same lift.
Like I said it looks great as is though
The fact that they are good in the snow was a major factor since I head to the mountains for skiing a lot, but I'm sure the 285's wouldn't have been too bad in the snow either. You two are probably right, I should have gone with the 285's, but I talked myself out of them :crybaby:. But the T4R is my daily driver and I commute about 70 miles/day, so I use that as an excuse for now :cheers:
I've had lots of questions about where I purchased the shocks. I bought the front 5100s off another member here who decided not to install them on his rig (lucky for me). I bought the rear 5100s from AJUSA.com. Here's the link to the rear shocks:
Bilstein 33-187174 Monotube Shock Absorber for 2005 TOYOTA 4RUNNER
Shipping is free. Use the promo code listed on their home page for an additional discount. It looks like you can also get the front 5100s here for just a few dollars more than I paid. Here's the link:
Bilstein 24-186711 Monotube Shock Absorber for 2005 TOYOTA 4RUNNER
It also says on their website that they price match if you can find a lower price elsewhere.
Can't wait to get my 5100s on. It should be within the next week or 2. I ordered them tonight from shockwarehouse.com who is also in fla so they said it will get here either 2marow or Saturday. And then I just have to wait till my friend gets back from hunting in Pa and when he does....it's lift time!
Can't wait to give some feedback and actual experiences :)
brings back memories of my rig when i first did my baby lift! nice!
Wait wait wait.....soooo you're going to talk sh!t on his lift because you have over cranked coilovers and a body lift???
Nice one dude, way to look like a d!ck, unless I read your post wrong. The OP seems very happy with his lift and setup, no reason to rain on his parade.
Jhunt
