Lift gate/ back door wont shut - 2010 T4R Trail
4RTrailnSC
Folks- I have searched and was wondering if I really do have to buy the whole lock assembly or does someone have a trick for me?
Toyota Part I found while searching: 69110-35081
My truck is 2010 T4R Trail Edition
Problem: back door/lift gate wont shut. Lock assembly is blocking and not fully turning to catch lock. First attempt I noticed the door kind of bounced up
Temp Solution: hold unlock switch under back window and use screwdriver to turn lock into a position so I can close
Thanks folks
Have you tried some lithium spray grease or similar (garage door lube, etc) to try and loosen up the physical latch? Or do you think it is a broken "return" spring or something of that sort?
Not sure on the replacement part - sorry :cool:
You need to make sure the entire dead body is the back and not hanging out. Otherwise it wont close correctly.
AndiGarage
