Lift: Height in inches
Devil_Dog
If you have a lift can you post the height from the ground to the roof in inches. I'm think of lifting my 15 Trail 2 inches or so and the parking garage has height restriction of 6'6''.
can't just measure yours and add 2 inches? only reason i say that is they're all going to be slightly different for several reasons.
Never mind. Funny guys. Kinda went Derrrrrrrrr special moment after I posted it. Not near the vehicle in anyway btw but found this:
Overall Height
w/o roof rack: 70.1in
w/ roof rack: 71.5in
Be sure you get some feedback on the lift you plan to install. I've had several different lifts on other trucks and almost never get the lift height listed in the ad. Often more or less actual lift.
Ditto this. As a matter of fact, most end up with more.
I wanted two inches and ONLY two inches for now so went with a 1.5" spacer in the rear and adjustable coilovers up front so my lift can grow if need be in the future. I had to crank the fronts WAYYY Down to get just 2 inches.
Overall Height
[MENTION=120125]Devil_Dog[/MENTION] Those heights (70.1 and 71.5 in) are from the Toyota spec sheet. Unfortunately, they are fantasy. The real height is about 74-75 inches. You should measure your own rig to be sure you will have enough clearance.
