Lift question before install tomorrow
exploded huh looks like i wasted my time typing all that
Yeah, I don't know what happened. I did exactly what you said and the strut came out no problem, but I'm assuming corrosion/rust didn't allow the top plate to separate like it should have when it was still bolted.
The first strut came out whole. I threw it on the floor and it separated. The top plate flew to one side, the shock flew to another. Luckily I was alone and it flew under the truck.
The second strut I removed the bottom bolt first and then tapped it with a hammer. It was much less violent than the first strut, but once that top nut was removed, it shot the top plate up into the fender well and the shock down onto the floor.
Now the instructions for re-assembly of the strut without a compressor were golden. Re-assembly took much less time than the disassembly. The rear was actually a lot more aggravating than the front. Dealing with the muffler/exhaust pipe right next to the upper shock mount and then trying to re-align the axle after I dropped it so far.
I'm just excited it's done. But now I really, really want 285's. :D
very weird i just jacked it up tell it compressed undid the top nut all the way lowered the jack slow and tap the bottom bolt out
Yep, did the same thing. It compressed like you said it would, it just didn't uncompress, lol. No worries, though, I appreciate all the help. :D
The 891's are really, really stiff. It feels like the shocks aren't being used at all, lol. Do they loosen up and settle over time?
Pictars:
I'm running the OME 60027 shocks in the rear. It's bone-jarringly stiff. It flexes great, but going over a bump it doesn't feel like it absorbs anything. It just kind of hops.
I'm running Rough Country shocks in the front and they're a good bit softer.
You think ARB would be willing to swap them out? Keep in mind I bought them used.
If they won't, I might try to sell the OMEs and buy Bilsteins. Unless the ride softens a little more here over the next few weeks.
seltzernator
