Lift question
4RUNN!N
I'm thinking about using the Cornfed 2.5" spacers in front and the OME 890s in the back, but unsure of what shocks to get. I will be doing mostly on-road driving with sometimes off-roading and maybe towing a 3,000 lb trailer. So is anyone is running a similar setup? What shocks are you using and how does it ride? Does the rear sag as much as stock with gear in the trunk or with a trailer? I'm looking for a slightly stiffer ride with less sag in the rear with gear. Any information or pics would be great.
Check out my post on the General section about air bags for the rear coils. there is also a good one about the same thing down a bit in this section. I put a set in last thr. and love them - just a bit stiffer and no sag. You could pump them up to 30psi and have it ride like a tank but I think 10-12 is perfect for unloaded.
Check it out and let us know what you decide.
2001ATL
