Loud ticking noise, at a loss, need help
Rjvenema
Hello, I'm new to this forum so thank you all in advance for any help.
I just got my Dads old 96 4runner, limited, 3.4L about three weeks ago. I had a knock sensor harness start acting up about a month ago and replaced the harness and the sensors about 2 weeks ago. While I was at it I replaced the valve covers. I replaced all gaskets and injector o-rings. Buttoned it all up and went to start it and it now is making a very very loud clicking noise. Sounds like the valves normally do but 10x+ louder. I can pinpoint it to the engine, but it is loud enough it is hard to pinpoint farther than that on location. if I had to guess is would say cylinder 1. I tore everything that I had taken apart down again and put all back together and noise is still there. The third time of taking apart and reassembling noise did not start out harmonic, but random for 5 seconds then became harmonic again. I am about to pull the valves off and replace them and the seats, but hoping these is something else I am missing.
Details:
No codes thrown
Engine runs smooth
Sound is harmonic and changes with engine speed
Sounds like a valve click but much louder
Does not make sounds while turning over
Does not make sound when EFI fuse is pulled
Borescope each cylinder didn't show any signs of impact or loose debris
Pulled each wire and engine slowed, but noise still present
Pulled each plug and wire, engine slowed but still noise present
Did a compression test and a leak down test
Cyl 1: 145 psi. 22% leak at 87psi
Cyl 2: 160 psi. 18% leak at 87psi
Cyl 3: 155 psi. 22% leak at 87psi
Cyl 4: 150 psi. 15% leak at 87psi
Cyl 5: 155 psi. 22% leak at 87psi
Cyl 6: 160 psi. 20% leak at 87psi
Did a valve clearance test, all were within specs. Cyl 5 one exhaust valve was 0.001 high.
Vacuum test runs steady at 46cm Hg
Replaced plugs and wires.
And here is the frustrating part. Neighbor is a mechanic and rebuilds engines at the Lexus dealership in Dallas and he can't figure it out either.
I am open to all ideas and thoughts.
Thank you all for your responses
Yes I replaces all gaskets with OEM gaskets. And used the Toyota gasket sealant for the 6 spots on each side for valve cover. Only thing not OEM are the spark plugs. They are NGK same plug that came out, just new
i had a pretty similar issue, got really loud ticking but only heard it from the inside of the car. can you only hear it from the inside or from the engine bay as well??
Get under the truck while it's running and listen right where the trans bolts up to the engine. If it sounds like it's coming from there it's probably the flex plate.
I would like to bump this thread. I am having the exact issue. The noise started about 2 months ago. I'm worried that the trailer I pulled from AZ to WA hurt the motor but it is running strong. Like the OP the ticking is coming from the top of the motor and is in sync with the RPMs
Take a hollow pipe 2-3 feet long and hold one end up against the engine, the other to your ear. The pipe will amplify the noise, and help you get a better idea of where it's coming from.
Or get an automotive stethoscope...
I agree with getting a stethoscope. Their only 5 bucks or so. Could you have gotten an old piece of gasket maker in an oil journal? Look at all the cam lobes and make sure none look dry. Get a bottle of engine flush, run it through, and change the oil.
Wish this hat been followed up on by the OP or the second problem poster... Very similar situation. Think it's down under. Flex paste or crank bearing... Valve clearances are all surprisingly spot on.
Judging by your signature you have a 4th gen so I’m not sure how relevant that would be for you since 3rd gen’s have a different engine.
Mike Sargent
