Lug pattern
If you are shopping for wheels, be sure to check the Bore size as well. The yotas need the large bore, something like 106mm? There are wheels out there with the right lug pattern, but the small bore for chevys I believe (wont work).
I know for a fact that Pro Comp wheels will work, but the center caps are a tight fit and need to be tapped into place. Getting them back off might be tricky too.
If you aren't wheel shopping you can ignore my input ! :cool:
EDIT: Come to think of it, the difference in the Pro Comps was that the small bore was Hub-centric and the large bore (for the Toys) was Lug-Centric. And Lug centric will work, it's what I am running right now.
Trdoffroad916
