Maintenance Issues
DJM2001
Hey guys, I know people ask this all the time, but I just hit 100,000 miles in my 4Runner and I was wondering what you guys suggest for maintenance that I should have worked on? I know the timing belt should be replaced pretty soon but didn't know exactly when other people do it. Thanks for the help.
90K intervals for the T/b. t/b, and water pump, thermostat, radiator cap, plugs, fluids, coolant of course. Misc. hoses and clamps possibly v/c gaskets as well.
Be sure to check the muffler bearings and top off the blinker fluid... :)
Also add fuel filter and you may want to change out the diff and transfer cases fluids to the list above...
Yip, all good suggestions - especially the muffler bearings. haha. BTW Kregg, your truck is looking sick! Add a transmission service to that list too if you want to cover all the bases.
Don't forget disc brake lube and to have your odometer turned back. :biggrin2:
It would be good to have a good thourough check over the whole truck. Inspect ball joints, CV boots, brakes, and rear axle seals.
