Map lights on when opening doors?
Morphyne
So when I open my drivers side door I have no light except for the courtesy light in the door. It just occurred to me that this may not be right. How do I address this?
If your trying to get your map lights to come on with the door open by themselves, your gunna be trying for a long time lol I think it's dumb they don't come on with the door open either ... I'm sure there is a way to wire it to do so though if you want to do so lol
There's a mod you can do where you tap into a wire in the driver side A pillar and it will turn on the map lights when you unlock and open the doors.
I wonder if there's an easier way to tap power from the dome light in the center of the car...
Probably still too much work to be worth it. Wish these had the same off/door/on switch as the others. Ah well...
:cry:
@J.A., so I have a sunroof and don't want to run an additional switch so do I just tap the white wire in that roof wire ribbon cable?
[MENTION=135111]cajone5[/MENTION] Just saw this, I ran mine from the dome light in the center. I don't have a sunroof, works great!
[MENTION=93193]morphious[/MENTION], so you wired the map lights as J.A. showed then dropped down your center overhead light and tapped which wires to make it work?? Any pics of the install?
[MENTION=136099]Ratubbs[/MENTION] I can't remember what I tapped, did this a while ago and don't have pics. I took a VOM and found which wire I needed to tap on the 3 wire ribbon cable.
Yes, but it is not the only white wire there at the dome light. It is at #2 position. Like the others have mentioned, use a test light or meter and check for the correct one. You would be looking for ground when the door is opened.
Such an awesome website. Kept me busy for a couple of days.
for a long time i kept having these wild eyed ideas on what i could do with the 'runner. crazy things like using side cameras hooked up to the turn signal....OH WAIT. JA already did that shit. every idea i think i had he did already. complete with drawings, parts, beautiful write-ups. awesome site indeed :thumb:
Agreed man, write ups & photos are top notch. So much effort put into the details.
Jhunt
