Massive garage sale, Bilsteins, OME, spacers, towing, interior, lights, etc.
pearlj10
Member
Finally cleaned out the garage and have the following for sale, all prices are obo. PM with offers. I'm located in Phoenix, AZ.
Bilstein 5100 front struts (F4-BE5-C477-TO) (6,000 miles) with Eibach springs (112620/327478-1) (2,000 miles) sold by Toytec fully assembled with top plates, etc. and set at the third setting (which provides roughly 3" lift with Eibach coils). Good used condition. $350 shipped for the complete assembly. SOLD!!!
Old Man Emu 60020 longer rear Nitrogen gas charged shocks (pair) with 8,000 miles. Good used condition. $100 shipped. SOLD!!!
Procomp ES9000 (#926514) 11.5" travel shocks with 2,000 miles, a couple of rock dings on shock bodies that don't affect performance, $50 shipped.
More to come!
OEM front coils, 4WD 4R, 4,000 miles, great shape, $50 shipped.
Toytec 1/2" aluminum top plate spacers (#TOP1-T) provides roughly 3/4" lift, great used condition, $40 shipped. SOLD!!!
One (1) Old Man Emu 10MM rear spacer (#150PR10R), great for minor drivers side lean compensation, new and never installed, $10 shipped. SOLD!!!
One (1) Daystar (#M03726) 1.5" Lift Black Poly Spacer), great for moderate drivers side lean compensation, new and never installed, $35 shipped.SOLD!!!
Pair of rear factory bumpstops, good used condition, $20 shipped. SOLD!!!
Pair of front lower links, one OEM and one Moog aftermarket, good used shape, $10 each shipped.
Pair of rear OEM lower links, good used shape (one has bushings/hardware, one does not), $10/$5 each shipped.
OEM air intake hose for 03-05 V6, good used condition, $10 shipped.
Superlift TruSpeed speedometer correction (with adjusting key), little use, $75shipped. SOLD!!!
New OTRATTW Carling Technologies -Series Contura II sealed rocker switch, green lens V1D1J66B (2 count), and new Carling Technologies Snap-In Switch brackets (2 ends), $10 shipped. SOLD!!!
OTRATTW Carling Technologies Snap-In Switch brackets (2 ends), new $3 shipped. SOLD!!!
Etrailer.com mini license plate light kit LP31CB, new in bag $5 shipped.
Lot of five (5) new and very slightly used 3022 festooned LED bulbs, and three (3) very slightly used 194 wedge LED bulbs. $10 shipped. SOLD!!!
Tan (fawn) map light/storage compartment unit in good shape (needs new metal clips [2] that are a buck or two each), $25 shipped.
OEM rear red "dummy" light housings (pair) (the ones in the bumper that don't light up), good used condition, $15 shipped. SOLD!!!
OEM turn signal light housing (pair) with sockets and lights, good used condition, $25 shipped.
OEM fog light housing (pair) with sockets and lights, good used condition, $25shipped. SOLD!!!
Denso 020100 turn signal flasher, perfect used condition $10 shipped.
One rear interior door light housing, good condition, $5 shipped.
One OEM gear shifter (SR5, not ltd), $10 shipped.
Two OEM rear armrests, good used condition, $10 each shipped.
OEM Toyota trailer hitch ball mount with 1 7/8" ball, good used condition, $25 shipped.
Two (2) chrome plated 2" trailer balls, each used once (yes, I lost these two times!), like new condition, $10 each shipped.
OEM trailer hitch assembly from 2003 4R, good used condition, $30 shipped. SOLD!!!
One OEM gauge cluster trim panel, good shape with one minor scratch in gray paint, $30 shipped.
Set of 20 Gorilla black 12x1.5mm acorn lugs with 4 wheel lock lugs and key (full set of 24) (BEST FOR AFTERMARKET WHEELS), installed once and ran for a week while I waited for spline lugs to be ordered, $50 shipped. SOLD!!!
OEM complete spare tire carrier assembly from 2003 4R, good used condition, $30 shipped. SOLD!!!
Shotgun the 5100's/Eibach spring combo and 1/2 toytec spacers
PM sent...forgot to mention in the PM but I have an american (Massena, NY) address they can be shipped to so it wouldn't be overly expensive or any hassle.
Already in line as of 2 hours ago on the 5100s along w/ the OMEs
Nice first post!
Thats fine. Just to clarify you realise the coils are not OME's right? Or are you talking about the shocks?
EDIT: clarified
Parts
Hey Ill take the spare tire carrier and the red dummy lights if the mounting tabs are intact. Interested in other parts also. Sending a pm for paypal address.
Hi!
I'll take the "One (1) Old Man Emu 10MM rear spacer (#150PR10R), great for minor drivers side lean compensation, new and never installed, $10 shipped."
PM sent
Updates:
OME 10 MM spacer sold to Sky.
Red dummy lights and spare tire carrier sold to 1st Timer.
