Mind the Gap! - Fixed gap between hood and body - 2014 TE
boyfester
During an off-road trip this past weekend, I noticed a large gap between my hood and body on both sides of my '14 TE. It was about 1/4-1/2" gap. I never paid too much attention to the hood before so I was worried that my monthly off-road expeditions had done something to the hood. I opened the hood expecting to see a rock or mud in between the rubber seals and bumpers but didn't see anything. I closed the hood firmly but the gap remained. Here are some pictures of the gap.
This is looking down towards the left headlight on the driver's side.
This is the left side.
And the right side.
As far as I could tell, the gaps were even on both sides. So I scoured this forum about how to adjust the hood and only found notes about a hood gap after people did some headlight upgrades. I scoured youtube and the internet and found out that two of the bumpers underneath the hood (Marked "A" in the following picture) are adjustable down and up by rotating them either clockwise or counterclockwise, respectively.
I ended up rotating them clockwise all the way to their limits and the gap still remained. I then removed them completely by unscrewing them and, still, the gap remained. So my next diagnosis was the bumpers on top of the radiator shroud. I removed these (they were in the locations marked "B" in the above picture) and the gap decreased by about half. Ah ha! I was onto something! If I pushed down on the middle of the hood, I could see through the grill that the hood latch had some clearance in it. I realized that if the entire hood latch could be lowered about 1/4 inch, it would eliminate the gap entirely. I was hoping that the holes on the latch were slotted and therefore, could be adjusted.
So I removed the black plastic covering the radiator to gain access to the latch. I removed the latch by removing the three bolts. Unfortunately, the bolt holes on the latch were not slotted. Bummer! Therefore, I took out the Dremel and opened up the two top holes about 1/4" upwards and opened up the bottom hole about 1/4" downwards. The screenshot below shows the direction of the grinding on the three holes.
I took off all the springs and hood latch cable to see how everything worked while it was apart which was a good thing. When I remounted the latch to its new lower position, part of the mechanism struck the metal framing which was connected to the body and the front grill. Therefore, I had to grind about 1/4" off of this as well to allow the latch parts to move freely. The picture below shows what I removed.
When it was all said and done, I lowered the latch about a 1/4" and put all the rubber bumpers back on. I found out that the "A" bumpers could remain but screwed in to their lowest positions. The "B" bumpers raised the hood again slightly again about 1/8" and so I removed these completely from the assembly. The following pictures are of the finished product.
Looking down at headlight from the driver's side again. Much more flush.
Left side
Right side
Mine is doing exactly the same thing.
And it was after doing a bit of a header into a sand dune at Pismo last year.
I also went through the steps you did for diagnosis. SO far I have not tried to modify anything. I can't for the life of me figure out what actually moved/bent to cause it! The very metal that the latch is one eventually holds the quarter panels on as well.
I made a post about it here:
http://www.toyota-4runner.org/maintenance-detailing/178071-any-body-repair-specilists-here.html
I was thinking of cutting off the hood latch hoop and macking it about 1/4 inch shorter and welding it back on. You're the first other person I've seen have the same thing happen.
Did you screw in the "A" bumpers in all the way yet or remove them? There was enough rubber cushion along the sides that these are somewhat redundant in my opinion. If that doesn't work, try popping off the non-adjustable "B" bumpers. Those had the most impact with regards to the bumpers.
Yeah I tried adjusted the bumpers, they were still properly adjusted as far as I could tell. It's as if that entire bar with all 4 bumpers and the latch attached has risen up to raise the hood, but then all the other plastic, headlights and quarter panels haven't... though they are all attached to the same piece of metal. It's bizarre!
I agree. I just can't remember if it was like this when I bought it. I'm usually a stickler about details so I think this happened recently, but I guess I could be wrong.
You know, come to think of it, earlier in the day I hit a whoop-de-do pretty hard with a considerable amount of force probably bottoming out the suspension and slamming the RCI skid plate up front. Is that skid plate connected to that framework?
I just looked, the skid plate is attached to the frame. But the front facia and everything that supports the front of the hood is attached to the body which has those big rubber mounts to the frame. SO I don't thing hitting the skid plate itself would cause it. But I do know that in my case I actually smushed the front bumber plastic into the sand enough to pop off one of the top plastic piece, and that could have bent stuff inside on the body internals. I just can't actually find anything bent though!
It does bother me when I look at it. It looks a lot nicer after your fix so I'm more motivated to take care of it now :D
My fix was pretty easy too. I was hoping that the now lowered hood would reduce the hood flexing around the scoop while driving but that didn't change. :(
2001ATL
