My 2017 Toyota 4Runner TRD Off Road. Build list with prices and pics..
Snake Eyes USA
My 2017 Toyota 4Runner Off Road Stock to Modified.
RPM Garage for work in Los Angeles area.
Best alignment in town. No rubbing and no wobble up to 102mph so far.
Battleborn Off Road for parts. Can't be beat!
Aiden James Customs for work in Orange County Area.
Champ at dealing with KDSS lean.
I experimented with undercoat protecting the bottom of my 4R with Frog Lube. So far so good. No gunking up or sand sticking to undercarriage.
1. Bilstein 6112 47-281202 B8 Heavy Load Front $570.00
2. Bilstein 5160 25-227611 B8 $310.00
3. SPC Control Arms 25480 $439.00
4. Old Man Emu OME 2895E Rear Coil $165.00
5. Bilstein Reservoir Mounts 11-176015 $84.00
6. X6S Slim Series 2D Amber/White 30inch LED Bar, LED Bar Harness Kit, X6S Wireless Remote, EX-X6S-150W-30-CB-KT $298.00
7. X6S Lens Amber Spot EX-X6S-LENS-AMR-SP $8.00
8. X6S Lens Amber Flood EX-X6S-LENS-AMR-FL $8.00
9. Toyota Side Mirror Blind Spot Left 87961-42D20 $44.79
10. Toyota Side Mirror Blind Spot Right 87931-42D50 $44.79
11. Warn Winch EVO VR 105 103253 $659.00
12. C4 Lo Pro Winch Bumper, 30inch cut out, Mid Height Bull Bar $847.00
13. CH4x4 “LoPro White” White Button $26.98
14. CH4x4 “LoPro Amber” Amber Button $26.98
15. Factor 55 Flatlink E Red 00080-01 $148.00
16. Iron Cross ¾ Galvanized D-Ring Shackles Red 1000-08 $47.26
17. Toyota Aluminum Oil Filter Cap 15620-31060 $18.32
18. Factor 55 Winch Lock 000011 $28.34
19. Spidertrax Wheel Spacers 1.25 inches WHS007 $169.49
20. Daystar Locking D-Ring Isolators KU70059BK $17.46
21. ARB RK9 Recovery Bag $376.00
22. TRD Off Road Decals $17.99
23. TRD Off Road Rim Decals $34.99
24. Andrews Powder Coating for C4 Bumper $600.00
25. Warn Winch Cover $50.36
26. RCI Rock Sliders 20degree, Top Plate, Black $945.00
27. TRD Pro Skid Plate KDSS Modified $175.00
28. Toyota Black Rear Valance Free
29. Toyota Skid Plate Mounting hardware PT938-00140-AA Free $23.04
30. Nitto Ridge Grapplers LT255/80/R17 E-Load 55lbs. (Pizza Cutters) $197.88 x5.
31. Anytime Front Camera with Natika camera upgrade. $161.78
32. Diode Dynamics SS3 (DD6191) Pro Type B Kit Yellow SAE Fog. $272.00
RCI Rock Sliders 20degree, with Top Plate.
RCI Rock Sliders 20degree, with Top Plate, Black $945.00
These have already paid for themselves. While the intention of buying these is for protection off road. You will quickly realize the sliders protect more on road. Ive had four people hit me and only lost a little slider paint and the other vehicles were damaged. If I didn't have the slider, my 4R would be in the shop.
#1 reason why I chose RCI over everybody else was the design. The slant cut at the ends will assist you in not getting something or yourself wedged between end of slider and vehicle.
C4 Bumper, Warn Winch, Xtreme LED Light Bar, Factor 55 Flatlink, Iron Cross Shackles.
The bumper is as centered and secured as can be. No issue just slight off center to the left about 1/8 inch.
Nitto Ridge Grapplers Pizza Cutters
Nitto Ridge Grapplers LT255/80/R17 E-Load 55lbs. $197.88 x5.
This size also fits in the spare.
Going with the Pizza Cutters I get an extra inch of differential lift over the wide tire users.
Plus when airing down, the foot print goes front to back vs wide tire footprints when aired down get wider.
Audio settings for stock and similar sized replacements. Mixed for driver priority.
Audio settings for the mix to be directed evenly to the driver. Based on the stock speakers and similar replacements.
Sound is my life. Emmy and Golden mic. awarded.
My 4Runner compared to others. Side by side.
Some shots for comparing and admiring.
Me when I popped my Off Road Cherry with my 4Runner and After.
Me when I popped my Off Road Cherry and After.
Rowher Flats, California
2 weeks owning my 4R stock a friend in a lifted modified Jeep took me through double black diamond trails in Rowher Flats, Ca.. I had no idea or clue. Pin Striped both sides end to end, top to bottom. Little undercarriage damage. Lower Link and Gas Tank Skid. No harm done. Amazing time. Felt it after the fact. Luckily, I found one of L.A.'s best detailers without breaking the bank and got 99% of the stripes out. You live and you learn. Regret nothing. This pic. was at the top of the mountain. High on life and the view. Hadn't noticed any of the damage yet.
Amazon. Was the last place I was checking. Was not expecting to save. I want to say it was for the set of 5 but I could be wrong. I can check later to be sure. And just to be clear that's per tire.
Where did you get Ridge Grapplers for below $200?
#Truth
Agreed. I did it on a clean fresh freeway straight away. And only did it once.
Saw so many posts about people doing lift and balance and getting wheel shake at around 60mph. So I wanted to test beyond what was being reported.
Nice build, but taking these things over 90 mph is essentially suicide.
Amaz....*types furiously*
...well I'll be a suck-egg mule...guess I know where my next set of rubber is coming from...
Amazon once again.
Ya, I try not to use Amazon as much as possible especially during Covid. Doing my best to support Mom and Pop before the big guys.
I wont be tire shopping for a while, but being an expat in the ME, Amazon is my source for a lot of stuff I cannot get here.
Then its your go to.
If its a main source of goods you cant get anywhere else, than all the power to you. Its a blessing then.
