Need a Little Rear Lift!!!
mochilln00
So I just got done Installing my stereo system, And everything rocks!! But the only unfortunate thing is that now with all that weight in the back(its actually not that much) the rear end sags just enough to look like trash. Id say it dropped a good 3/4". Does anybody have any ideas on what I can do to bring it back up to normal (or maybe a little higher). Everything is stock, but I might be adding some bilstein shocks later.....
you can add a rear coil spacer. Stock spring tends to sag. I would go with OME rear springs, but i dont know if they carry stock height springs. GL on your search.
Well I want keep as much of the stock (comfort) ride as I can, I appologize for my ignorance, but im assuming that new springs will hurt that. Is there any body that makes a 1" or 3/4" rear spring spacer???
I had a problem with the rear of my 96 with it almost bottoming out when I would tow my camper. I didn't want to spend a lot of money to replace the factory springs because they were fine. I ordered some air bladders for the rear and they helped alot. The good thing about them is that you can adjust the pressure and actually raise the rear end several inches with all factory parts. I think Firestone makes the air bladders.
NVBASSJUNKIE
