Need Help! I'm STUPID! Battery Cable in 2004 V6
dpross16
Hello everyone. I am very stupid and I admit it. Now that we have that over with, will you guys please find it in your hearts to help me? I have a 2004 4Runner SR5. Long story short, my clamp on my positive battery cable broke off at the terminal. So, I think to myself, well I will just put a new clamp on... not so easy, everything is like melted together and I would have to cut a significant amount of cable off to replace it and then it would not fit. So, the next best thing is, I will just change the cable, how hard could that be? Well, I was a little pressed for time and didn't do any research on the matter and unhooked a cable and installed the new one directly from the battery. Well, whatever I did, when I tried to start the truck, resulted in smoke coming up from underneath the engine. I wish I had a picture to show what I connected it to because I have no idea but I am guessing that it was the starter. My questions are... Can anyone tell me how to change the battery cable? And does anyone know what I fried and how do I fix it. I assume that I need to install a new starter, does anyone have pictures of that? I looked in the Chiltons book and basically it says remove this bolt, take this bolt off and wha-lah! all fixed. Something tells me it isnt that easy. HELP!!!
At this point we'd need pictures and even then addressing all the possible damage. You may want to take it to a mechanic, at best you burned up some high amp cables, fuses, and fusible links; at worst your looking at a harness(es),module(s), ect.
Just because you made a mistake does not mean your stupid. Look at it as a learning lesson. Stay positive Broham.
It's honestly not that complicated, but I agree with others that you probably grounded out the positive some how. I rewired all the positive and negative cables in the engine on my acura and had zero issues. I also had to wire a new negative ground for my battery on my 03. Sounds like if you're struggling that you should take others' advice and get it to a mechanic
Update?
I used to be mechanically retarded. Don't feel bad no one wakes up and knows everything. I used to work on jets in the military, I wasn't retarded, but still managed to burn down a jet. I caused over 10 million in total damages.
Anyway what was the outcome? Did you figure it out or take it to a shop?
I guess we all make mistakes but GD.... You're on a payment plan to pay it back I take it? Also, OP hasn't been back since late June.
