Need help
JMF97SR5RUNNER
I'm having a problem with my 97 runner cranking of alot before it starts, it has 190k on it. I just replaced the fuel pressure regulator and that helped a little bit. Anyone have any ideas on what it could be?
Is your battery good, or your alternator giving enough charge? If it's cranking for a while but eventually starting, I would start by taking a meter and checking these two things. 2nd step would probably want to check the starter out.
Instead of cranking the key over in one motion, turn the key to the on position so the fuel pump kicks on and sends some fuel up for a few seconds. Then try turning it over, see if it still cranks long. That will rule out a fuel issue. Otherwise, long crank times would most likely be the starter(If it sounds like the cranking is nice and strong.) Or the starter contacts.
I did the plugs and wires about a year ago, also already did the fuel filter. The turn the key on trick helps, I have also noticed that it gets worse as the fuel level in the tank gets lower.
Sounds like your fuel pump is on it's way out. If it still runs well though I wouldn't worry about it too much. Just turn to the ON position to build a little pressure, then crank.
If I want to change the fuel pump anyway, do I have to drop the tank or is there a cut out under the rear seat to get to it?
There is a cut out under the rear seat but it will only be good for unplugging the electrical connections before dropping the tank. I posted a pic of the location on one of Gerdo's threads that he started with a very similiar problem.
