Need Pic of Stock Strut Mounts
Alabamaguy
Trying to figure out if this is a top plate spacer or not. I know there's a small spacer on top of the spring, but is the piece above it a spacer as well or is that just an aftermarket strut mount?
Yes, Both pieces are spacers. Looks like someone used normal bolts and nuts to bolt it to top of spring perch. You can see the bolt head starting to dig into the spacers that its rubbing against..
Looks like about 2 - 2.5 inch lift???
I don't know how much lift it has. Each spacer appears to be about 3/4" thick. I'm shooting for about 3"...could I just replace the bottom spacer with a 2.5" piece...or would I be better off with a 3" spacer kit that combines a new upper and lower?
Eventually I'll go to a true spring lift but money is tight right now and I'm trying to get 33" tall tires to fit without too much rubbing.
If it was me, I would just get one spacer.
I'm sure someone else will chime in here because I don't know to much myself about them. Haven't dealt with them a lot like some people here.
DJNutshell
