Need recomendation: Code reader purchase
sakoluvr
I need a recommendation as to what code reader I should buy. Currently have a '97, 2001 and a 2002 4runner in the stable. Also have a 2000 F150.
If you want the ability to see and clear codes, plus additional functionality, like extra "gauges", you might want to consider a ScanGauge II.
I have cables routed nicely in each of our cars, and I just move the unit where it's needed; although it resides in the Runner.
https://www.scangauge.com/products/scangauge-ii/
Usually about 140-160 dollars...
ScanGauge II
for sure
read, clear, and freeze codes.
real time information (up to 4 at once)
works on OBDII and easy to move from one car to another
different display colors and light settings
:blah:
i feel weird when i drive a car without one. I had mine forever.
Reviving this thread I am looking at a Bluedriver any thoughts good or bad. I was think of leaving it on alot of the time to monitor things like engine temp, Trans temp ect.:lmao:
That's about $80 more than I would spend for this capability. A simple wifi enabled device with free app is sufficient to read and clear codes. With DashCommand, you can monitor several data points. other apps might expand that. Wouldn't drop $100 on this tool with so many other options available.
For the Toyota and Lexus (newer) vehicles for more control I have a 64 bit OBD2 to USB cable/driver with Techstream.
I also have a $15 bluetooth adapter and torque on my phone - which is great for all obd2 cars plus real time monitoring (like watching trans temps in the LX470 while towing a large trailer).
2nd not spending that kind of money for basic diagnostics. There is *nothing* advanced about the 3rd gen 4runner system, the cheapest of the cheap will do absolutely everything that Can be done.
I have 3 options. $15 Techstream (aliexpress) which, with a computer, allows me to do 100% of what any Toyota Dealer can do with the available system. The downside is portability.
A ~$20 BAFX bluetooth/OBD adapter (was supposed to be the best "cheap" option) combined with Torque or the $10 Torque Pro does nearly everything the Techstream software can do, and everything more normal people care about (monitoring what little can be monitored, clearing codes) on this vehicle. It falls down when you get into vehicles with CANBUS systems.
A ~$200 all vehicles CANBUS adapter that works with any given vehicles diagnostic software (like Techstream). I bought this for my two other vehicles, which are both riddled with CANBUS and forgot about it when I'd ordered the Techstream cable ~ though the cheap cable is easier to use.
There's not a whole lot to monitor on the 3rd Gen 4runners, this is absolutely Everything (via Techstream):
If you have a smartphone, just buy one that works with that. You're not going to gain anything over a $3 ELM unit by spending $100+ on a Bluedrive unit (for this vehicle). Ditto with the ODBLink unit ~ it's marketing in most cases, with Maybe some CANBUS functionality via a smartphone for a few.
A good scan tool to keep in the vehicle is a launch CRP129E.
This can be snagged for close to $200 and it’s not like a lot of scan tools that you sift through manufacturer specific questions it can complete a VIN read and goes into the manufacturer specific scan.
Additionally it has good live data and graphing capabilities which are a must for a lot of diagnostic approaches.
Hope that’s helpful.
I have a bluedriver, and it is excellent. I use it for scanning non-GM vehicles that come through work. With that being said it is overkill for our generation 4Runner. Stick with a cheapie bluetooth obd2 reader and app unless you want to monitor data constantly then look into something like a scangauge 2 or ultragauge.
