Need some help
Morphyne
Replacing LCAs today and i have a stuck cam bolt. I got the the front DS off and the rear DS nut.But not the rear bolt. It will not move. Currently soaking in a mixture of Pb blaster and WD-40. My question is am I doing this wrong? If not any advice? I have a kobalt 20v 1/2" impact that's not cutting it and a variety of breaker bars.
WD40 is a waste.
Do you have a propane torch?
Heat will work wonders, as will hitting tbe head of the bolt with a hammer. It all helps break the corrision.
Well I'm going to have my son try and turn it while I go game on the end of the bolt with a bfh. If that doesnt work I'll use a ball joint press. If that doesnt work then it'll be sawzall time. I have new cam bolts on order and should be here tomorrow.
tuṣṭāva
