Need suspension advise
direwolf74
Installed toytec boss kit w/ diff drop last weekend, got it aligned and I'm over all very happy with it, goes straight as an arrow. I'm getting vibration at only 55 mph to about 70 mph, any thoughts ? Also do I need adj. pan hard bar, rear control arms, and rear sway bar adjustment brackets? Which is most important, if I had to do one at a time?$ Thanks for input.
Balance your tires, that's why you're getting that vibration probably.
You don't need an adjustable panhard, or rear links, or new sway bar links. If I was going to do them I would get new sway bar links first, then get new upper links (or both uppers and lowers but the uppers are super weak) and the panhard last, but again none of them are mandatory.
Thanks snivilous, I haven't put my new tires on yet, hopefully tomorrow or Sunday. Upgrading to 265/75/16 duratracs. I have a hard time believing it's the tires since I've had them on for 40,000 miles with no vibration. I'm thinking it has to do with the changed driveline angles, poss cv's, or u joint? Any insight or similar experiences,
utkrstam
