*NEW* '96-'02 4Runner 2.0 BOSS Resi with Adjuster!
ToyTec Lifts
*NEW*
2.0 Boss coilover with adjustable reservoir. Perfect for ultimate front suspension tuning ability on your 96-02 4Runner or your 96-04 Tacoma. With ride height adjustment from 1-3 inches paired with ride quality adjustment, you'll be ready to take that truck off road this upcoming season. (Will not fit 5 lug)
9604RES - ToyTec BOSS Front Coil Overs with Remote Reservoir and Adjusters (95.5-04 Taco & 96-02 4Runner)
Just when I thought I had made up my mind about my next lift upgrade. How do these compare to a 2.5" coilover?
Hello Twan,
Every shock company will have its benefits for specific use. So to compare our new Boss Resi w/ adjuster, we would need to know what 2.5 shock you are comparing it to and what your long term plans are for your 4Runner. For instance, do you or are you going to add additional weight? If so, how much? Is this 4Runner going to be a daily driver or is it going to be a OHV only?
Give us a call or send a PM so we can help set you up and determine the best application for your ride.
-Drew
these look great, but I am curious if you have any plans to do something with the bilstein 6112 series? Seeing that it has the larger shock body. Also, how do these compare to kings with the resi and compression adjustor? I have a 97 4runner with the 2.7 that I use for rock crawling and some desert driving. I was going to buy the kings, but just saw these and now I am stuck.
So I have the old ToyTec coilovers and the shocks are pretty much shot.
Are the replacement Bilstein shocks even still available? If yes, how much? I believe the part number is: F4-BE5-6930-H5.
Any chance for additional savings via an introductory group buy?
What REAR shock would you recommend these be paired with? I have the ToyTec SuperFlex rears.
PM Sent.
