• TAP is reportedly Out of Business Oct. 2022 per this thread.
New ARB Fridge | ZERO Fridge Freezer
Who says you can’t have your cake and eat it too?
Be the envy of the campsite with a new ARB Zero Dual-Zone Fridge Freezer,
serving drinks AND ice cream at the same time!
Whether you’re a weekend warrior or long-term remote traveller, ARB has
the perfect solution to keep your food, drinks, and frozen goods sorted.
Zero Fridge Freezer Range Features & Benefits
• Dual, independently-controlled cooling zones (dual-zone models only)
• Each zone can be set to fridge, freeze, or off
• Removable compartment divider and internal lid (73QT dual-zone only)
• Integrated wireless monitoring & control via compatible Bluetooth-enabled devices (LINX,
Android, & IOS)
• Boost function for rapid cool-down
• Anti-condensation technology
• Highly-efficient, variable-speed compressor
• Convenient USB 5V, 3000mA outlet for charging mobile devices (fridge must be connected to
DC or AC power source for charging)
• Dual-DC power inlet at opposing ends for customized installations
• Front-AC power inlet for quick home or powered-site connection
• Tough, durable, steel outer casing
• Full height corner mouldings for added protection
• Recessed carry handles with integrated tie-down points
• Quick-release, front-opening lid with non-slip glass/bottle provision (47QT only)
• Quick-release, reversible, side-opening lid/s with non-slip glass/bottle provision (63QT, 73QT
& 101QT)
• Easy-view LED display
• Low power draw LED interior light/s
• Versatile, removable internal basket system with provision for tall items/bottles
Specifications
Capacity – Zero 47QT
47QT Single Zone: 65 x 375ml cans
Cooling Capacity: -8°F to +50°F
Weight: 47.6lbs
External Dimensions (in); (L) 26.6 (W) 16.7 (H) 19.5
Internal Dimensions;
Upper Compartment (in); (L) 19 (W) 11.5 (H) 8
Lower Compartment (in); (L) 12.4 (W) 11.5 (H) 7.1
Power Voltage: 12/24V DC / 100-240V AC
Integrated-Battery Protection System Consumption 0.8Ah*
* DC12V set at 41°F, 89.6°F ambient temperature
Capacity – Zero 63QT
63QT Single Zone: 96 x 375ml cans
Weight: 54.2lbs
External Dimensions (in); (L)29.7 (W) 18.5 (H) 19.5
Internal Dimensions
Upper Compartment (in); (L) 22.8 (W) 12.8 (H) 7.8
Lower Compartment (in); (L) 15.8 (W) 12.8 (H) 7.1
Consumption: 0.8Ah*
Capacity – Zero 73QT DZ
73QT Dual-Zone (25QT/48QT)
87 x 375ml cans with divider, 108 without
Weight: 62.4lbs
External Dimensions (in); (L) 29.7 (W) 18.5 (H) 22.2
Internal Dimensions
Front Zone - Upper Compartment (in); (L) 15 (W) 12.8 (H) 10.4
Front Zone - Lower Compartment (in); (L) 8 (W) 12.8 (H) 7.1
Rear Zone (in); (L) 6.7 (W) 12.8 (H) 17.5
Integrated Battery Protection System
Consumption: 2.9Ah*
* DC12V set at 5°F zone 1, 37.4°F zone 2, 89.6°F ambient temperature
Capacity – Zero 101QT DZ
101QT Dual Zone (43QT/58QT): 144 x 375ml cans
Weight: 72.5lbs
External Dimensions (in); (L) 36.8 (W) 21.5 (H) 20
Internal Dimensions
Front Zone - Upper Compartment (in); (L) 13.9 (W) 15.9 (H) 8.2
Front Zone - Lower Compartment (in); (L) 6.9 (W) 15.9 (H) 7.1
Rear Zone (in); (L) 13.9 (W) 15.9 (H) 15.3
Consumption: 3.1Ah*
* 12VDC set 5°F zone 1, 37.4°F zone 2, 89.6°F ambient temperature
For more details - Click Here
The All New Zero Fridge Freezer by ARB has Officially Been Released.
Items are Now Shipping!
For everyone that has already placed an order, your Zero Fridge Freezer has already shipped.
Thank you!!
_
Thank You!
Wanted to thank you so much for your help in securing an Arb Zero 73qt! You went above and beyond to secure one from a warehouse in Florida that shipped right away and called with updates. This fits perfect in back; now just waiting for the DFG fridge slide to be delivered...
Looks Great!
Thanks for sharing
_
seltzernator
