New Arrivials!!! 2023 New Generation LED Bulbs
lasfit
official vendor
Calling all truck owners!
Lasfit has just released brand new LAair series All-in-One Design LED bulb. Apart from the mini size that is 1:1 with Halogen Bulbs we have also increased its light output to be more powerful. LAair Series
To show our appreciation for the support of 4Runner enthusiasts in the forum, we now offer 5 sponsorship slots to experience our new products for 4Runner owners! Don't miss this opportunity, interested parties can contact us at [email protected]⏰
p.s.US shipping address ONLY!!!
1:1 OEM Halogen Bulbs Design
1:1 OEM Halogen Bulbs Design means you can perfectly replace halogen bulbs without worrying about fitment issues or whether the dust cover can close, as they are designed to fit seamlessly with the OEM rubber dust cover and prevent any dust, water, or debris from entering the headlight housing.
Super Brightness with Clear Output Beam Pattern
Truly 35W, 3800LM, 6000K per Bulb with 12PCS LED chips present, the visual output can be enhanced, offering a brighter and wider lighting range. The lighting source is positioned in the same location as halogen bulbs and pairs flawlessly with projector or reflector headlights to produce a clear, well-defined light beam pattern with a sharp cut-off. It has consistently perfect beam patterns without glare.
Upgraded Cooling System with Built-in Temperature-Control System
The L-shaped exterior integrates a high-power fan and uses an upgraded heat dissipation system to ensure a longer service life. The 20mm cooling fan expels the heat efficiently, while the built-in temperature-control system ensures that the LED bulbs operate within optimal temperature limits.
So why wait? Space issues will no longer hinder you! Order now and experience the difference for yourself! Remember to participate in our sponsor activity first! Limited spots available, first come first served! LAair Series
DJNutshell
