New light bar, welded, custom mounts. Pics
kolelt
I used to have a different rear led bar. Which got stolen, they simply unscrewed the Allen key bolts and cut the wire. This time, I made the mounts out of steel, because the mounts I bought were aluminum and you can't weld aluminum to steel bolts. So I made new mounts and got everything powder coated. The read light is 21.5" 4D lense from miamioffroad. Front is 41.5" with slag factory mounts , also I welded the bolts.
Since part of the mount is steel and part is aluminum, the part that is steel I noticed touched the roof rack, so I threw a weld on there to so it won't fall downward.
2001ATL
