New member 4Runner 2008 Limited V8
Arthur4R
Hello all,
I was considering getting the 5th gen 4Runner, after some research I noticed the current vehicle body was soon going to change and I said to my self "if I find a good used 4th gen 4Runner" (which are really tough to get) I will get it otherwise I would get a 2016 4Runner Trail Premium. After reading all the common issues on these vehicles and looking at more then a handful I finally found the one.
It's a 2008 Toyota 4Runner V8 4.7 Nav, Bluetooth and rear adjustable suspension. Msrp on the vehicle was $43,xxx 1 previous owner with 163,354 miles on it. Finding one with nav and bluetooth was almost impossible seems to be such a rare feature let alone the rear adjustable suspension this is the only 4Runner I seen so far with this option.
Now before purchasing it I looked out for common issues including rust, I was very surprised that this vehicle has no rust ( vehicle is from Maine) because it has anti rust coating under the whole vehicle black paint/tar sort of material. To me that's a good sign that previous owner cared and wanted a vehicle to last a lifetime. Mechanically the vehicle is great shape I took it to my mechanic, we lifted the vehicle checked out for any leaks,bushings, axles, control arms etc etc. Everything came back fine I asked my mechanic " Hey how much miles do you think this vehicle has" he looked and said " I would say about 80k at most" when I mentioned it had 163,xxx he called over the owner and said look at the condition of this vehicle it is unbelievable. No accidents and original paint everywhere expect a rear bumper (probably previous owned backed into something).
Now the fun part starts maintenance
- replaced front low beams and front fog lights with 4300k Hid kits (love the road visibility)
- Bought a used set of front back and cargo area husky water proof mats from a member here
- Replaced engine oil with 5w30 Mobil 1 synthetic and Toyota oil filter
- Cabin and air filter replaced with Toyota oem filters
- Front, Back and center differential oil replacement with Mobil 1 synthetic 75w90 ( 6 bottles were enough)
- Replaced F&R rotors (centric premium) and F&R brake pads (Akebono) and upgraded to 5th gen calipers F&R Centric rebuild and painted with G2 caliper paint kit black and flushed brake fluid
- Rotated and balanced all 4 tires ( I noticed a wobble in the steering wheel at speeds of 80mph and I knew I needed a good balancing job all is perfect now)
- Interior needed some loving cleaned and polished everything
- Hardwired my Valentine one
- Car had the famous drive train clunk ( I am familiar with this issue on my friends 2009 GX470 ) I just did not know all you needed a good lubing job on the shafts to have it go away Thanks to the forum a lot of great helpful information
- On order some LEDS for those horrible reverse bulbs and interior lighting
- On order OEM Cluster lens ( my cluster lens is scratched up and cloudy tried cleaning it but little to none improvement just going to change it out total cost $31 shipped)
- Added Scosche magic mount pro dash
- Added Reese tow hitch ball with Reese step that attaches around the ball
Did you ask just what the past owner was towing with his 4Runner?
I would make sure that height lifting thing at the rear was in good condition, if it fails it's a bunch of money to get fixed. And good luck.
Height control works with no issues, I don't think the previous owner even towed with this car.
The underside looks fantastic. I picked up an 08 from Massachussetts with only 38k miles just last summer and I can tell you the mine does not look that good.
Cheers!
Cheers!
Yea hard to find a 4Runner that does not have a lot of rust let alone that is rust proof treated, when I was in my mechanics shop getting brake pad job done, a 2005 4Runner came to have his rear brake pads replaced. Once they lifted the vehicle I looked underneath it did not have a single spot that was rust free. It looked really bad and only had about 100k miles on it.
Rare spec and insanely clean underneath for a northeastern truck, congrats!
Thanks a lot, I feel the same way. Usually cars from Maine are rusted throughout. They get some harsh winters up there.
OP, what common issues did you look for?
From this forum I gathered rust and to make sure the all 3 modes of the 4WD works properly.
I'm just entering the market for a 4Runner, looking at 5th and 4th gen, probably leaning towards the 4th gen due to its classic good looks...
That underbody looks absolutely pristine, you sure that vehicle was even driven? :)
Some common issues from top of my head, Rust, Drive train clunk, center diff lock ( seems to be an issue where it won't engage), 4wd or 4wd low not engaging, head gasket (only on a v6 model) mine is a V8, and just all the oils to see if they were maintained properly. Obviously check out for paint work, frame damage, and car fax for accidents.
I think it was parked in the garage for all of 163,xxx miles :)
