New Tundra Bilstein 5100s - perch spacing the same?
Supermoney
Hi guys, as most of you know Bilstein updated the tundra 5100 we all used.
Old Part #: 24-188265
New Part #: 24-261425
To the people that have used both versions, or have been able to compare them side by side, are the perch settings identical? Beside the 5th, as I know that has slightly changed.
I know most people ran the 2nd / 3rd perch on these, is it the same for the new ones?
From wheelersoffroad.com:
"6/2/17 NOTE: 24-188265 has been superseded by 24-261425. The only difference we see is that the 261425's top clip groove is slightly lower than the -188265 (which will yield a little less lift on the top groove) and the -261425 comes with some bump stop spacers (big flat washers)."
Are you using the Tundra 5100's because of the added notches for lift tweaking or for different purposes? Upgrading soon and curious.
BillM777
