New wheels and tires, and concerns...
thor999
Got these wheels:
(17" Sequoia / Tundra '05 - '07) and want to have Goodyear Wrangler DuraTrac Tires LT285/70R17 mounted on them. Running on OME 2.5" lift, '01 SR5 4wd...
1) would I need to do anything to prevent rubbing?
2) will I be able to do the 231mm Tundra brake upgrade?
3) will I need an alignment? (going from stock size Yoko Geo HT's)
4) should I add those "wheel balancing beads"?
5) is it worth the extra hundred dollars to get them from Discount Tire as opposed to Walmart? (Mom works there and gets 20% discount)
TIA for your time and consideration!
***EDIT*** these are 16" wheels apparently!
I hope you haven't bought the tires yet, because these are 16" rims! They are the 16" TRD rims for Tundras in 2005-2006, so I assume they fit the bigger calipers. I always recommend an alignment when putting on new rubber. I got my BFG's from Discount Tire, and they sometimes offer mfr rebates when running promotions. I got a $100 visa card when using the Discount Tire credit card.
Hmmm you are probably right, I bought them last year and threw them in storage... nope didn't buy tires yet! Am taking them down to Discount Tire to get a test fit tomorrow, should I edit my post?
