Yay! First thread on the forums!
Sucks that's it's to find a problem.
I tried to go a little hill the other day and my 97 SR5 struggled to even get started on the first bump.
I had rear wheel spin, so I just wrote it off as open rear diff = crap.
Yesterday I decided to finally bleed the front brakes properly.
With only 1 wheel off the ground and transfer case in 2HI, I could spin the axle that is off the ground, but the center shaft would not move at all!!!
From what I understand, either of the CV is broken of the differential itself is shot/gone.
When I spin the driver-side wheel, I can hear some faint gear meshing coming from the diff.
Passenger side is silent (at least the bearing is good!).
There does not seem to be an apparent breakage...
I am about to remove both CVs, as regardless if it's the CVs or diff, they need to be removed to fix it.
CVs are nonexistent at any salvage yard around here, diff are common however (Quebec, Canada).
That, plus frame rot make me want to sell what's left/good and shop for a new 4R...
Anyone had a similar issue? Was it the CVs? How rare is it to have a diff break that way and not cause a rattle/noise when driving (either 2Hi or 4Hi)??
