OEM wheels that fit 4Runner with no lift
robhurlburt
Looking to change the look of my 4runner. I was wondering what other wheels will fit the truck. I know 5th gens fit, how about 6th gen? Tundra? Taco? Any others?
Any pictures you guys want to post?
Try the search function this has been discussed a ton of times. I know for a fact newer Tundra rims won't work since the are 5 lug rims.
search for OEM:
"Sorry - no matches. Please try some different terms."
OEM is to short I would assume
wow, so all your searching is "OEM" you realize that can pull up every single part on the car?
try this, click on search, then advanced, select 4th gen, at top type "Wheels" then say title only, thats a good start. Mid size Toyota SUV/Truck with 6 lugs all will most likely fit. 6 lugs is the first thing you need to look for. Put a little more effort into search and you will be ok. Try plasti dipping and or painting stock wheels.
Using "OEM" itself will not generate search returns you need to be more specific such as "OEM wheels 4th Gen 4Runner". All you need to is substitute other parts for wheels in the search to generate returns on other parts.
Jhunt
